The Sherman filterbank has negative sustain on it's ADSR, never seen this done elsewhere. It provides mastersweeps!
Maybe it's easy to do on DSP, I don't know. I suspect this requires different ADSR, but maybe is can be done via modulation/offsets or something.
http://www.sherman.be did it the analog way, I think he'll be glad to assist when you would try it to!!
negative sustain
that's correct. I did not mean Env. Inversion, that's done before.
Like in:
'value'(after attack)=100
'value'(after decay) = -50
This new Sustain value will be pos/neg. inverse to Env. Depth, which is the 'value'(after attack).
<font size=-1>[ This Message was edited by: atomic on 2002-02-18 10:02 ]</font>
Like in:
http://www.sherman.be/extras/manual2en.pdf p. 24-33 explains the ADSR
<font size=-1>[ This Message was edited by: atomic on 2002-02-18 10:28 ]</font>
