effects on auxgroup vs only within channels ?
nebelfuerst
Post by nebelfuerst »
In the old days, I used external gear for compression, reverb and enhancing.
I grouped many channels to one aux-path and fed it to the external gear.
Within scope, I do the same, but I think, scope is powerfull to copy&paste all effects to each single channel.
Is there an advantage/disadvantage to work with grouped effects ?
Re: effects on auxgroup vs only within channels ?
yes, and it depends on what you are trying to accomplish.
if it is a reverb that will provide an ambience for a whole mix, of course you want to use an aux bus.
if it is compression on a specific instrument, that should be inserted on the instrument's track.
if it is a compressor for several mics, like on a drumset, then sending everything to a group and compressing the group makes the most sense.
special FX for one track might as well be an insert on the track.
just do what makes most sense....
