one of two neat features implemented is that aftertouch can be used to influence the vectoring of each axis bipolarly via some mod signal massaging.
the other neato feature is two vu meters which show axis mod levels. the levels are only good for x, and y each as a whole, not each oscillator on either end of each axis.
so as you see say your adjusting the x axis vector control with the y axis on 0 you will see the y axis mod level meter drop as you move to any "fringe" (-63, +64) region on the x axis. the x axis level meter will stay the same throughout, because of the virute of equal power crossfading.
still, figuring that i could use vu meters for this somewhat limited purpose was greatly appreciated by my sometimes confused self and looks pretty cool as they are whiring up and down in tandem
the patch is dry, and mono. it beneifits greatly from outboard processing and stereoizing effects.
i would have at least added a modulatable panner, but i stretched my dsp capacity to all it could go (really!).
based on a nord modular <a href="http://www.cim.mcgill.ca/~clark/nordmod ... utorial</a href> by James J. Clark.
large read me, for the readers, that is calling out to be read.
more detail is provided there.
thanks.
//c
*note*... fixed [ init ] preset (wasn't completely initialized), and edited the readme to clean up some of my barble gable.
some of the tables in the readme
are messed up when viewing in ie 5. i tried saving with different line breaks and carriage return types to no good effect not sure what the problem is, for reference i'm using BBedit lite on a mac, which displays the text file perfectly.
<font size=-1>[ This Message was edited by: castol on 2002-04-26 08:38 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/modular/vectra.jpg" BORDER="0">
