Logic 5
vaporubs
Post by vaporubs »
For Audio Drivers what are the best to choose in Logic
subhuman
Post by subhuman »
ASIO.
Highest bit rate that you need, even 32bit ASIO works. Higher bit depth require more harddrive space and system resources, for highest track count use lower bit depth.
vaporubs
Post by vaporubs »
Thanks Subhuman....Inside of pulsar routing I see you can make several asio channels...I Dont understand ASIO so well, why would I need multiple in's and out's of ASIO. In logic I chose ASIO scope as one driver 2 driver one is wavplayer....Should I check any of the others?
you might want to use logic as a multitrack machine.(it's nice to be able to go in or out with multiple tracks,especially when mixing elsewhere :wink: )
oh and you don't need to check both types of drivers.just use asio.if you need to use another program and have it stream to logic,you can use the wav drivers with that one.(you can use another wav driver for another program,hint hint)just connect all the proper ins and outs thru a mixer in sfp.
<font size=-1>[ This Message was edited by: garyb on 2002-05-17 19:23 ]</font>
