not a device. a dll for fixing the voice crash in SFP
Neutron
Post by Neutron »
<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .dll"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Utility<BR> <a name="planetz-tag"></a>Related To: Scope Fusion Platform 3.1<BR> _____________________________________<BR><BR> this is from creamware it is a temp fix -untill the patch comes out- for the problem with number of voices causing a crash. just put it in your app/dll folder
originaly from Knut Andreas Frøyen
sandrob
Post by sandrob »
sometimes when i try to set poliphony in livebar my sfp crashed! if i understand this will fix that problem?
if yes - i give vote 10!! :smile:
btw: my sfp crashed sometimes when i try to add screen-set or add new preset?
now i trying to crash sfp by adding about 100 new screen-sets but can't crash :smile:
is this fix for that problem or it's because i don't use sts3000 anymore? actualy i had more stability problems when i had sts in project.
<font size=-1>[ This Message was edited by: sandrob on 2002-05-18 15:24 ]</font>
Neutron
Post by Neutron »
It is a newer version so thay probably fixed some other UI related problems.
sandrob
Post by sandrob »
ooooops! it's not fix for this. now my sfp crashed when i try to rename screen-set :sad:
fortunately, this not happends every time.
subhuman
Post by subhuman »
Yes that fixes it!
The only thing I did differently was first close SFP down completely (including tray), then I put this file in the C:SFPappbinpepbase directory after making a backup of the original file. I can't make it crash with the text box double click anymore! I think if it doesn't solve it for you to be sure you overwrote the original file (after making backup in case).
sandrob
Post by sandrob »
probably you have right and i hope it's fix, but i don't understand now.
i have this original file in: app/bin/PepBase not in: app/dll
so, where to put this file?!?! :???:
samplaire
Post by samplaire »
Sandro, watch the path sub wrote and compare it with yours. . . Yeah, the same. . . The conclusion: just replace (with backup!) in the same directory you found the original file. . . . . . . . . Works?
I think The Artist Formerly Known As DeFex (Neutron) wrote the path as an example not to take it literally....
BTW mathematically: Neutron < Atom'ic . :smile:
BTW2 the Mac SFP is not affected with the bug AFAIK.
Sir SamPlaire
<font size=-1>[ This Message was edited by: samplaire on 2002-05-21 07:31 ]</font>
Thanks Neutron, that's a usefull 'device' for all of us :smile: :smile:
Sir SamPlaire
lol
Creamwareatically it takes many many atoms to create a Neutron (device)
<font size=-1>[ This Message was edited by: at0mic on 2002-05-21 22:06 ]</font>
samplaire
Post by samplaire »
That's wht I only noticed that, without any coment! :cool:
sandrob
Post by sandrob »
:smile:
when he said that i must copy over original file then i found this file with window's "find" options. i didn't notifice that sub's already write correct adress, because neutron's info saying: sfp/app/dll :roll:
sorry, sorry, sorry :oops:
hm, now i trying to crash sfp but can't :grin:
<font size=-2>got my mojo working, but it just won't work on you</font>
<font size=-1>[ This Message was edited by: sandrob on 2002-05-21 08:18 ]</font>
samplaire
Post by samplaire »
Good news, Sandro :smile:
Sir SamPlaire
<font size=-1>[ This Message was edited by: samplaire on 2002-05-21 13:04 ]</font>
Neutron
Post by Neutron »
seems like i have been dissed somewhere here.
just go into the SFP folder press f3 and find the file and replace it, wherever it is.
<font size=-1>[ This Message was edited by: Neutron on 2002-05-21 21:09 ]</font>
