Hi there,
I have decided to do a completly new XP partition strictly for audio, I will be installing SFP 3.1 and I am wondering if anyone can help me out on tips for the installation? I have read all the threads on this forum and can't seem to get any firm answers.
i.e.
-Is it advicable or not to disable ACPI during the install?
"I have heard both too install in standard PC mode and/or acpi mode"
Is there any difinitive set of tweaks that have been proven to work?
and any other installation tips/links would be great.
thanks for the help,
nuence
New XP Audio partition with SFP 3.1
-Windows XP does quite a good job at ACPI, but if I were not on a dual CPU config, I'd get Standard PC still I think. Make sure you do not have IRQ conflicts.
-Follow the guide here
-I would only turn System Restore off once everything's installed and running smooth.
-From a clean machine, install Video-card and LAN first, to get WinUpdate. Then insert the DSP card(s) into your pc and install SFP.
-Then see which of the tweaks on the above link applicable to your machine -and apply them
-Defrag after each program install, even if Windoze tells you it's not necessary.
You should be fine then
Another very usefull link, when you're starting form zero. I took it from the Win2k/XP twxeaks page here:
http://www.nuendo.com/help/help.phtml?a ... 59&hsec=04
