Free X Over Frequency Separator + Test generator
celmo
Post by celmo »
<a name="planetz-file"></a><a href="http://www.celmo.com/Download/Crossover ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Utility<BR> _____________________________________<BR><BR> The same one with an addition:
a test generator, with Pink and white noise and sine variable oscillator, for the calibration of your loudspeakers system
enjoy
celmo<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/dev ... erator.gif" BORDER="0">
arish
Post by arish »
some explanation on this devies can be nice .
t
samplaire
Post by samplaire »
It's something like a knife - devides the whole frequency range into 2 parts: lower and higher - the edge of the 2 parts is adjusted by the knob. What is it for? If for instance you have a ready-to-use (listen to) mix that lacks some atmosphere (and you have no separate tracks of the mix) - just add some reverb to the higher part leaving the lower one with no processing. But there are more things you can do with it - it depends on your imagination (as with Lego blocks :wink:.. ) - connect 3 of the devices the way you can have 6 frequency ranges.... yummy...
The generator part is self-describing - generates white and pink noises as well as a sinus sound with adjustable frequency.
Correct me if I'm wrong
Sir SamPlaire
<font size=-1>[ This Message was edited by: samplaire on 2002-06-01 13:18 ]</font>
celmo
Post by celmo »
Originally it was only a frequency separatot, a kind of crossover filter.
This is useful to separate lo and hi frequencies, to drive separately two way of a monitor loudspeaker.
You could use it also to separate the low or sub frequencies from the signal (below 80 or 100 Hz) to drive a sub woofer.
And finally, I added a noise and frequencies generator, which can be useful to "appreciate" the frequencies going to each loudspeaker.
But this kit could be used for SFX too, depending of your imagination and creativity.
allo ??? SFX creaters?
celmo
<font size=-1>[ This Message was edited by: Celmo on 2002-06-01 13:23 ]</font>
celmo
Post by celmo »
Sorry, samplaire...
We answered exactly at the same time, and we told the same things...
Not wrong at all !!!
samplaire
Post by samplaire »
Oops!
I didn't even know about the original purpose :lol:
samplaire
Post by samplaire »
BTW it's very useful device - thank you!!! And it does 100% what is intended to so 10 points go to... :cool:
Sir SamPlaire
<font size=-1>[ This Message was edited by: samplaire on 2002-06-02 14:34 ]</font>
