Hi!
Why is it impossible to automate an effect put in to a MultiFxS's Slot or the MultiFXS slot ON/OFF buttons if this MultiFx's is in a mixer or auxrack or in an other MultiFXs????
I've tried to put a MultiFx's into the old BigmixerV2B and there it works perfectly!
But the BIgmixer's insert are MONO so that's not good for me.
Why is it blocked?
Where is it blocked? In the Host that contains the MultiFxs, or is it blocked in the MultiFXs?
Or is it because of the MultiFxs has own MIDI in port? But then why does it work in the Bigmixerv2b?
Is it a bug of CW or a conscious restriction?
Many questions..
I've tried old hosts, MD8.dev and md4s.dev (insert racks, downloaded from the download section) but the MIDI automation neither works.
Is it possible that someone - who has a Scope DSP construction kit - eliminates this restriction from the MutiFXs device or eliminates the MIDI In maybe that's the problem...
I'm getting mad with this creamware stuff.
Everything is fine and works well, good effects, good possibilities, but there is always one little 'Thing' that makes it unusable..
So if you have any suggestion please reply me.
Thank You: Padre
