Quick and dirty patch with j9k comparator
Michu
Post by Michu »
<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Type: Synth<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar 3.x<BR> <a name="planetz-tag"></a>Requires: Modular 2<BR> _____________________________________<BR><BR> in this patch signal of osc1 is compared with output of modulation mixer if it has greater value it's output is used otherwise output of osc2 is used.
for modulation=0 osc1 makes upper half of waveform and osc2 lower.
6dB lowpass serves for smoothing osc-flipping signal.
ConstantB can be used for manual modulation of oscillators ratio<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/modular/scompmg.jpg" BORDER="0">
j9k
Post by j9k »
thanks for posting the modular. i'm glad some one is putting the stuff to work.
j9k
Ben Walker
Post by Ben Walker »
I've been building a patch which uses the comparator with a big sample pool. Unfortunately, the modular still has the bug which means that all samples in the pool are saved with each preset, so the patch rapidly grows to big to be distributed.
But I'm having fun working with the module and will post the patch once this bug has been fixed.
Cheers,
Ben
Michu
Post by Michu »
Ben,
couldn't you use that standalone pool?
Ben Walker
Last time I tried I couldn't get the standalone pool to open in SFP 3.1a, but I've not tried very hard to verify this.
I'm in the middle of building a new PC (upgrading from PII 350mhz to PIV 2.2ghz - very exciting) and until that's done I'm not really doing anything else.
Also the standalone pool seems to be unusable by Mac users, so I wanted to see if the Mod pool preset problem was fixed in 3.1, but its not.
Ben
Michu
Post by Michu »
:sad:
i see...
i am still on 3.01
