I have had a quick browse through related threads but none resolved my problem.
I have recently purchased an A-16 AD/DA converter.
With NOTHING ELSE CONNECTED in the routing window, when I connect the ADAT source to the mixer within Pulsar2, I get a loud static - intense white noise with a high pitched ring/modulation - on the connected channel. The input meters, of course, go way into the red.
This occurs REGARDLESS of whether the the A-16 is connected to the Pulsar2 card, or not. ( This connection is via light-pipe ) So it appears not directly related to the A-16 but appears more of an issue within Pulsar.
A few other observations:
- all lights on the A-16 are green - even during the "static"
- it occurs in either Master/Slave configuration
- THERE ARE NO RED LIGHTS DISPLAYED routing window ( in Pulsar ) suggesting no ADAT connection but the A-16 appears to be talking to Pulsar because the sample rate changes within the Sample Rate window ( in Puslar ) when I change the sample rate on the A-16.
- the A-16 performed properly on another PC when I took it back to the store to try to work out this problem.
- I de/re-installed Pulsar 3.1a ( including re-installing the drivers )
I believe this is not directly related to the A-16 - but I am absolutely confused as to its cause as it does suggest an issue within Pulsar.
System:
933 p3, 512, w98SE, Pulsar 3.1a, Sonar XL 2.0, matrox G550
Any suggestion will be appreciated.
A-16 Ultra - Loud static when ADAT connects with mixer
algorhythm
bigBadWolf
bigBadWolf
