when i tried to load wave files into
sts 3000 it is failed.
						Can't load wave files
You're going to need to be a bit more specific !
Have you ever been able to load them ?
The way it should be possible is:
get the program (multi-sample) you want to load the wav file into. Go to key-group tab, and right-click to creat a new group. In this screen, go to the zones tab. Then you should be able to drag-and-drop wav files into the zone (usually 1).
If this is what you are doing and it doesn't work, something is clearly wrong . . .
