Communication error with Scope?!
roxysound
Post by roxysound »
Help. I have my Scope-board for a year now and it worked well until now. (system: SFP 3.01, 7ms latency (44.1Khz), Adat 2x8, 4x Asio2 in Cubase VST 5.01. On a pc Pentium 1 Ghz, 512 mbRam, AsusChipset)
When I run VST and record audio, since one week, the system crashes: a giant beep through my monitors shake me up, and with that noize the message occurs:
"A communication error with Scope (Board 0) has occured. This problem can normally be corrected by reloading the DSP's. Do you want to try that?" When I answer Yes, nothing happend, the pc stucks.
When I say No, I must restart Scope (or the pc).
What's the matter here? Has it something to do with my AsioSetup? (I went from one to four Asio-channels in VST).
Please help me with this problem.
marcuspocus
Post by marcuspocus »
Check for heat problem, since it's summer, heat can cause this exact error. Also, if you have 2 or more boards, clean the STDM cable with pure alcohol, this also help alot for clean connection.
Anyway, my first try would be to add a fan, or open the case a just try with an additional fan to see if error still occur.
I have met the exact same problem last year during summer times, and fixed it with a fan blowing directly on the pci cards, creamware cards specificaly... Those Sharcs are generating alot of heat!!!
roxysound
Post by roxysound »
Thanks, that could be the problem. My room is very hot, and I also have a blanket on top of my pc... For the time of a year it was a good solution, until now. Let's hope it was the problem indeed.
Steve-o
Post by Steve-o »
Did you solve the problem? I have the same and I can't solve it!
Steve
my powersupply with reduced fan speed almost collapsed this week due to the lovely current temperatures :grin:
Steve-o
Post by Steve-o »
Any news? Lower temp. better performance?? Steve
