Newbie Question: CD Audio Playback
after install Pulsar2 and its SFP 3.1, I can play a standard audio CD in my Cd-rom drive normally with windows media player but now, I can't here what media player is playing (it can be played but no sound)
So i just want to know how to check in the routing windows or do i have to do some settings at windows media player to get this CD playback work again.
thanks in advance
thanks in advance
I THINK that you first need to check in settings>control panel>multimedia what drivers are being used. If they are NOT puslar ones you should be given the choice to send play and record to pulsar.
Then open up a new project and check that WAVE SOURCE software module is loaded and connected to the right and left channels of the mixer. Then make sure that the channel you have routed WAVE SOURCE to is being mixed. You should get sound now. If you don't, is the MASTER display showing any input (i.e. flashing green stuff ?) If YES and you are not getting sound, try re-booting but if this doesn't work, ask someone else ! If NO again, you'll have to ask someone else. My tech skills pale into comparison . . .
marcuspocus
more information
I can play Mp3 files and all wave format files (*.wav)
but no CD audio
(it can not be played in digital mode like macapulus said) <---- ???
i don't understand about this digital mode ...
but when i first installed the card and software, it can be play while i didn't set any thing in Multimedia player. (i think it is analogue mode as defualt)
help help
but no CD audio
help help
'Digital Audio' from cd is reading bits'n'bytes from Cd by your player, instead of a cdrom sending the audio analog out to an audio card, this uses a small cable between cdrom and audio card. Pulsar has no connection for analog audio from cd. It needs to pass cdrom->MediaPlayer->SFP->cards.
Standard I thought XP set cdroms to read digital audio, so you won't need the utility normally...
I've uploaded a utility to enable digital audio from cdrom:
http://www.planetz.com/forums/viewtopic ... forum=13&0
<font size=-1>[ This Message was edited by: at0mic on 2002-09-08 11:09 ]</font>
ok...I tried everything
still dosnt get any sound
as i said before my CD drive is fine ....first time i installed the Pulsar and SFP it can play AUDIO CD
but now it dosnt.
if the audio cd have to play in digital mode
I think i have some problems here coz when i click "digitally playback" in WinMediaPlayer, it won't work. it said that i have to play in analogue instead coz my driver has problem ...(but it doesnt say which one)
any idea how to fix this ?? please
i tried winamp = same result
but now it dosnt.
Okay a few more ideas ...
1. Be sure your CDROM is DMA-enabled ... (check the driver settings Winkey+Pause)
2. Is the Adaptec ASPI layer installed? http://www.adaptec.com
3. When it was playing before -- was it playing through your Pulsar or did you have a different soundcard/onboard sound with a cable?
ok...
i just tried what u said ...
-dma checked
-Aspi installed
and 3. answer is i can played it 4-5 times since i firstime used pulsar.
but now it still doesnt get any sound from audio CD but mp3 files can be played (it come to wave source1 <---not sure is it the same with audio CD here)
windowmedia player say
"We have determined that Windows Media Player cannot accurately read your CD drive digitally. Windows Media therefor switch to reading your cd drive in analog mode. Your CD's will play,but the following items will not work when playing CD's Visualization, Srs Wow effect, Graphic EQ."
i have 2 drives
master is Matshita DVD-rom SR-8584A
slave is ATAPI CD-R/RW 8x4x32
really need help
thanks for suggesttion
-dma checked
-Aspi installed
i have 2 drives
really need help
i gived up.
My Cd property cannot be ticked for digital.
so..i take my Pulsar out off the machine then format c: ,re-install windows.
all cd work digitally again with sound on mainboard..but i dont think i will use pulsar on this system again...
looking to buy a whole new pc for pulsar only
any suggestion...??
i m considering to get MaC too ...
any suggestion...??
