Devices/synths and different sampling rates
CreepJoint
Post by CreepJoint »
Ive just been playing with the modular 2 with the a standard patch that comes from creamware and decided to test the sound quality at different sampling rates. Ive just found that this effects the envelope rate. Is this right for example, a patch with a long cutoff decay is shorter at 96kHz than lower rates. Is this right? I know the theory behind sampling rates but I didnt expect this to happen within the sfp environment with plugins. Surely this is wrong. If you decide to change the sampling rate in the middle of a project this is going to stuff everything up!
<font size=-1>[ This Message was edited by: CreepJoint on 2002-09-08 09:37 ]</font>
kimgr
Post by kimgr »
That is fixed in 3.1c, what version are you running ?
Kim.
