<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Type: drum replacer<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar 3.x<BR> <a name="planetz-tag"></a>Requires: mod.III<BR> _____________________________________<BR><BR> hello friends,
here is a drum replacer made with modIII.
it takes incoming stereo grooves and replaces them.
some presets output a result very similar to the original, other modify it a lot, but everything is related also to the type and complexity of the source material.
of course it can be used with single sound drum tracks, in wich case it is an extremely powerful device, as it is build to output three sounds.
a small mp3 groove is included, so you can immediatly hook the patch to a mediaplayer and check the presets.
for those with mod2 only i posted a similar patch some time ago called "drum replacer", you can find it easily if you select to wiew the page by poster.
i hope you like it. cheers.
