Hi all,
I've build PC's for several musicians and found a problem similar to all my cliënts;
All machines I sold ran Windows 2000, they've used Cubase VST 5.1
They all have Creamware PulsarXTC with 3.1a software.
No in cubase in XTC mode there is no midi signal when pressing keys on the midi keyboard, when I load the sfp, and set focus on an instrument, I have midi in ?!?
Does anybody know how to fix this ?
Last question, another customer uses Logic Audio Platinum latest release, he doesn't use XTC mode, if he changes focus from logic to sfp the logic complains with an asio overload... Any idea's ?
Thanks a lot for your time.
Regards,
Jeroen.
Midi in not working in XTC mode
virtualstudio
Open task manager. Right click on logic.exe, or whatever the executable is called, and change the cpu priority from normal to high. This only works for the current session, but there is a more permanent solution by modifying the command line in the program shortcut, check this thread out for more info
http://www.planetz.com/forums/viewtopic ... 88&forum=3
