wavelab....
Zoloft
Post by Zoloft »
Howdy everybody, I don't get any audiosignal out of the Wavelab 4.0 demo. What should I do to get Cubase, Pulsar and Wavelab working well together. Tanxie a lot!
marcuspocus
Post by marcuspocus »
for cubase, you need the 'asio src' module connected to your mixer
For Wavelab, you need the 'Wave Src' module connected to your mixer...
To record to Cubase, you need something connected to the 'asio dest' module
To record to wavelab, you need something connected to the 'wave dest' module.
Any combination is valid
Wavelab 4.0 now supports asio
Though if your sequencer is using the asio you'll of course need to use the wav source/dest.
froggy
Post by froggy »
does this work when using spdif connection as well?
marcuspocus
Yes, but you still have to connect the spdif src to wav destination if you want to record the incomming sdpif signal, or wav src to spdif if you monitor wavelab output to a spdif ddevice....
froggy
Post by froggy »
mmmm, ok, i'll try 2night when i'll get home....
thank's marcus pocus
