Velocity on pulsar synth dont work.
Omb
Post by Omb »
hello there.
i'm working with the pulsar synth with SX as
sequencer and when i change the velocity in
the window where i arrange the note's (i dont remwember it's name ) it doesn't affect on the synth of the pulsar .
what is wierd to me is that the velocity is
working with the sts.
any hsuggestion ?
cheers
omb
King of Snake
Post by King of Snake »
Care to tell us which synth it is you're using?
samplaire
Post by samplaire »
It is nowhere written that a synth has to be velocity sensive. It depends on the design of particular synth. Sometimes you have to set the velocity sesitivity manually on the synth's surface while sometimes you can't change that parameter. So your question is too wide - please be more precise.
spacef
Post by spacef »
In "Pulsar" (or SFP) there are synths with velocity, others without.... depends on the one you are using, and if velocity is activated (on what, filter? gain?)
Nestor
Post by Nestor »
Almost all VST-DXI synths have velocity, but just a few have velocity in Pulsar. If you can’t control velocity in any of your synths, there it is a problem. Please, try different ones and take note of which ones catch the information then post here. Cheers.
