Polyphony in Kontakt... Problems (Cubase SX)
mano
Post by mano »
For some reason if I start playing some fast chords I have the following problems:
. clicks and pops (usually when CPU gauge is at 70% which happens fast)
. a lot of times, the notes get stuck
Isnt it supposed to handle hundreds of voices?
1Ghz P3
Intel motherboard (D815EEA2)
512MB PC133
Windows XP Pro - Optimized to death
Midiman US Midisport 8x8
Roland RD-150 master keyboard
Pulsar II (6 DSP)
A16 Ultra
Cubase SX
ULLI / Settings: 44,1Khz - 16Bit - 13ms
I tried both in XTC mode (which I normally use) and classic SFP - same results.
If I look at the number of voices on the Kontakt window, it's only at 10 or 12 when it starts crackling.
It sucks, I don't think I am pushing it that hard. Thanks in advance for your help.
<font size=-1>[ This Message was edited by: mano1.com on 2003-01-06 00:03 ]</font>
wilbertenserink
Post by wilbertenserink »
I think it is related to a cpu overload. Glitches are caused by a very short cpu overload. It happens so fast that the cubase cpu meter doesn't show it.
I think kontakt is a good sampler, but using effects and modulation causes more use of cpu
regards Wilbert
I agree.
Using Kontakt on a dual 1.8ghz Xeon box here I have to be VERY conservative with the way I construct groups and use insert & send effects. In fact if there's not a good reason to use the effect within Kontakt it's probably smarter to rely on your preferred external plugin for the given situation.
Also I might mention that since you're using Cubase we're probably assuming you're using the ASIO Scope drivers.
