software on creamware SFP. It is "udak"...
A soft that doing real time aleatory loops on a buffer, wich can be
infinitely re-reccorded with no cut, the first buffer is blended to
the second before that vanishes step by step (it could be great to increase
a fonction that lets the user choose how long the two buffers goes blended).
there is pitch, grain and formant parameter buttons. This could be a
good tool to play live with SFP, connect it on auxilliary send of the table
and pass any source through at any moment. i can't say technical things about
that soft, but it should be eazy tou find.
That's my first wish...
 The second is a device that can convert an audio
 The second is a device that can convert an audiosignal to a midi info. As exemple, to pass a sound in a reverb (and the
device) and set the device on the decay or the room size, the volume of the
sound will change itself the parameter... (a masterverb with midi automation
could be fine too)...
