ASIO:System Overload with Logic Platinum 5.5
chungle
Post by chungle »
ASIO:
System Overload.
The audio engine was not able to
process all required data in time
(-10011)
When playin Audio for about 30-60sec I am getting this error! even when I only use 5 Audio tracks, I used to use about 20 Tracks and had not any problem, but since I upgrade my system I am getting this problems
Anyone could help
<font size=-1>[ This Message was edited by: chungle on 2003-01-12 08:47 ]</font>
Tony B
Post by Tony B »
Put each HDs as masters on separate IDE channels. Make sure no background applications are running when playing back tracks. Your Sequencer is seeing something using resources.
post some more info of your system's config.
is dma enabled?
djody
Post by djody »
Larger disk buffer in the asio setup.
Ana the process buffe size ( i use jumbo )
Katerz
