Still trying to get systemlink to work. I got a connection now, but because of crackles and stuff it's unusable.
My question is: "What do I need to hook up 2 computers (1x pulsar1 and 1 x pulsar2) through adat?" What else but 2 toslink cables hooked up between the cards, is needed? Because hooking it up straight (pulsar1 <=> pulsar2) does not seem to work.
Am I trying the impossible? Do I need extra devices in my pulsar projects? Do I need an extra (hardware) device?
Any help is appreciated. Thanks in advance!
						ADAT conection between 2 pulsar cards possible?
That's exactly what I do, it liks correctly (Changig samplerate on 'master' pulsar also changes samplerate on 'slave' pulsar.) The links show up allright. I can hear the sound comming in normally, but (even with nothing playing at all) it's unusable since it crackles all the way. So the sound that plays stays OK, but there's a bad distortion on the line also
Would it make a difference if I use the other adat connection? (B instead of A)?
Thanks again!
Thanks again!
				One2Waziru
