version 30 detected... can't install
assaf
Post by assaf »
hello,
i got the gigabyte ga-7vaxp mtherboard, amd xp 1800.
with acpi i installed the driver ok but when i want to install the software it gives me that error...
with standard pc the xp won't start...
i moved the card to another slot but still no good...i tried with standard pc and it's the same...
i don't have any PnP option in my bios...
help...
<font size=-1>[ This Message was edited by: assaf on 2003-01-17 02:16 ]</font>
<font size=-1>[ This Message was edited by: assaf on 2003-01-17 02:42 ]</font>
Tony B
Post by Tony B »
You must install from 3.1a. Reboot then upgrade to 3.1c. There must be a way to turn Plug and Play OS to "NO" in the Bios. Install XP in normal mode. Don't choose STANDARD PC. The drivers MUST be installed first. Uninstall it to a folder then select update drivers in the Control Panel and go to that folder. If you try to run SFP just so it would not install the drivers first. The software cannot be installed without the DRIVERS installed.
assaf
Post by assaf »
i got the 3.1c version.
now correct me if i'm wrong...
1.I need to install xp in the normal way..ok?
2.install the motherboard drivers...ok?
3.install sfp 3.1a version driver,reboot..?
4.uninstall 3.1a and update to 3.1c only after i copy the 3.1c driver to a folder,reboot..?
5.install the SFP software...
is this ok?
<font size=-1>[ This Message was edited by: assaf on 2003-01-19 01:13 ]</font>
<font size=-1>[ This Message was edited by: assaf on 2003-01-19 02:05 ]</font>
no.do NOT uninstall v3.1a drivers.instal sfp v3.1a. install 3.1c over it.
<font size=-1>[ This Message was edited by: garyb on 2003-01-19 02:47 ]</font>
assaf
Post by assaf »
sorry, my mistake... 3.1c is an update...
ok,i'll try it when i get back home.
Tony B
Post by Tony B »
Yes. That's it UPGRADE 3.1a!!!!!!!!!!!to 3.1c
Tony B
Post by Tony B »
What I neant was unzip the drivers from the SFP 3.1a installation disk to a folder. By default it would be the UNZIP folder. Navigate to that folder first from the "update driver" in Device Manager and select "SCOPE INF" install it. At this point you can install the software. Put in the 3.1c CD and install normally. The system would reboot. WAIT for a while until the system see the next upgrade. Post again if you have problem.
<font size=-1>[ This Message was edited by: abre on 2003-01-19 04:41 ]</font>
assaf
Post by assaf »
ok, i got you... i downloaded the sfp 3.1a from the creamware website, i'll try to install it first(driver and software) then i'll try to update the driver and install the 3.1c version.
ok.
Tony B
Post by Tony B »
Yes 3.1a DRIVERS FIRST then software. 3.1c drivers then software.
assaf
Post by assaf »
god help us...
