Using Sounddiver with PowerSampler?
GlynH
Post by GlynH »
I have read that the Creamware cards have poor MIDI I/O but can anyone out there please run me through setting up an SFP Project suitable for use with Sounddiver?
I have my Korg Trinity Plus connected to the MIDI on the PowerSampler and need to know how/what settings I need in the SFP Project/Routing window?
Please bear in mind I am a novice so a simple load MIDI A and connect it to MIDI DestA type description would be most welcome! :smile:
Thanks & regards,
-=Glyn=-
<font size=-1>[ This Message was edited by: GlynH on 2003-01-17 20:26 ]</font>
jupiter8
Post by jupiter8 »
If you have midi working you should'nt change
anything. Otherwise it is Pulsar midi source to Seq dest. and seq source to Pulsar midi dest.
Hope this makes sense.
GlynH
Post by GlynH »
Thanks for the quick reply and yes it does make sense...but...
If I do as you suggest SoundDiver gives the following error on startup - twice;
While trying to open MIDI port CreamWare MIDI In/Out2 in function"midiInOpen". the error "Undefined external error". occured.
Make sure that the MIDI interface is connected and switched on.
To overcome this error I added a second Software I/O Sequencer MIDI Source2 and linked it to a second Sequencer MIDI Destination2 - not sure whether this is correct or not?
I'm guessing my problem lies here...
Now SoundDiver loads normally and when I select Trinity Plus and ask it to scan it goes through all my MIDI ports (SW1000XG 1 & 2 plus CreamWare MIDI In/Out1 & 2.
When it comes to CreamWare MIDI In/Out2 it then proceeds to scan all 16 MIDI channels with the progress bar reporting Waiting for incoming MIDI data. Press ESC to abort.
This process takes @15 minutes! then it will give the following error;
No new Devices found!
Please check MIDI cables and Devices.
I'm guessing it is something simple to do with the SFP Routing but I am stuck at this point.
Thanks & regards,
-=Glyn=-
petal
Post by petal »
I know this isn't much help, but I have the exact same problem trying to hook Soundiver up to my Roland D-20 through my Elektra-card!?
Thomas :sad:
siberiansun
Post by siberiansun »
in device manager, check the properties for your cw card. under settings->midi setup the number of devices is probably set to "2" try setting it to"1". it helped me when logic showed the same error message you got.
petal
Post by petal »
Cool - I'll try that when I get back home!
Cheers!
Thomas :smile:
petal
Post by petal »
Yes - It works!
Thanks a lot!
Thomas :smile:
