win. 98se ore xp
You actually got abre's version on the correct answer. Opinions are diverse i this matter. You will find people doing better with XP and others doing best with 98se.
i also had a 3 days nightmare under sx, now it seems to be solved (seems to be a dongle issue, when you install patches etc). So i would advise xp/sx too, but if there were some cubase rep around me, they would be dead right now
edited : about the latency : if you could give more details it's appreciated. I beleive it's for wave only, but not asio, right or wrong?
<font size=-1>[ This Message was edited by: spacef on 2003-01-27 18:26 ]</font>
mmm, for asio ? i thought asio was dependant of your hardware. Here i use version 1 board from creamware (no ulli, 13 ms latency max). if someone could be so kind as to post a "tip and trick" or enlight me in how i could improve this....
<font size=-1>[ This Message was edited by: spacef on 2003-01-28 02:41 ]</font>
With your current setup, it might be taken into considderation, that XP uses more of your computers power - especially your RAM.
