96 KHz.....BOYAH !
ShaTNorsK
Post by ShaTNorsK »
elow,
its been a while since ive posted here..had no problems :lol:, yeah right..
Anyways,
if I export a song in reason or cubase in 24/96 do i have to select it in the samplerate SFP option also ?And when burning to a cd, should I export 24/96 also ??
Thank you all..
LAters
sandrob
Post by sandrob »
for audio cd you must convert to 16/44.1
ShaTNorsK
Post by ShaTNorsK »
elow,
Ok so when do i use 24/96 then ?
LAters
sandrob
Post by sandrob »
some producents use to say that's not good idea to do resamplering.
i heard also that if you want to work in higher resolution is better to use 88.2 instead 96 because of easyer and better resampling to 44.1 (half).
problem is because you can't set 88.2 in pulsar. you need external master for that samplerate.
re-biting with dithering is ok.
On 2003-02-01 05:15, ShaTNorsK wrote:
elow,
LAters
when you are recording for dvd......
ShaTNorsK
Post by ShaTNorsK »
Wotcha,
Cheers for that :smile:
p.s: rob im from slovenia :wink:
LAters
sandrob
Post by sandrob »
slovenia?!?! you mean 'dezela'? :roll: :wink:
nice to see you here :smile:
ShaTNorsK
Post by ShaTNorsK »
elow,
Yup, nice to see you too..:smile: I come to Korcula every summer !
LAters
sandrob
Post by sandrob »
ha! let me know when you'll come again?! :smile:
braincell
Post by braincell »
I think DVD audio uses 96 KHZ but DVD movies use 44.1. (with surround). DVD audio is a rare format. Correct me if I am wrong. There is also the Super CD to compete with DVD audio.
RedSun
Post by RedSun »
Actually, the bitrate/samplerate for DVD movies is not fixed. It is mostly a space vs quality tradeoff. You could make a DVD movie with 24bits/96Khz audio but it would have to be quite short as the audio would gobble all the available space.
Also, I just rembered, there is a limit to the total data bandwidth used by your program, which is equivalent to playing the DVD at 1x speed. So, if you put very high quality audio, the video stream would have to be highly compressed.
Note that the bandwidth limitation is not applicable to non streaming DATA(ie: a DVD-RAM disk used to store files and programs).
RedSun .:.
<font size=-1>[ This Message was edited by: RedSun on 2003-02-03 22:45 ]</font>
imho the high sampling rates aren't introduced for fidelity's sake, but because they simplify the design of digital filters, which results in reduced production cost of consumer (mass-)equipment.
It's also a great sales argument directed to those who either don't know or can't hear anyway.
Produce for less and charge more :wink:
braincell
Post by braincell »
I've never heard 96 KHZ but from everything I have read about it, there is a clear and obvious improvement in sound quality.
