array copy file problem
sandrob
Post by sandrob »
i have strange problem here. when i want to load some synth (sb404, synchrotron...) in project i have this:
then, after few clicks ok, ok, ok, ok, ok... i can open synth and then works normal :???:
sandrob
Post by sandrob »
sfp reinstal fixed this! :smile:
devo
Post by devo »
I got the same problem the other week when reinstalling on my new DAW. Tried to reinstall and still ran into the same problem.
Don't know what caused (done the same install before without trouble) but I finally tracked the problem down to a bad ArrayCopy.pep lurking in the SFP/App/Script directory. I replaced it by hand from installation files and then the error disappeared.
Bad version was of about 4K of size and the working one is approx 1K.
I just thought I would add that info in case someone else fails to fix by reinstall.
sandrob
Post by sandrob »
i tried overinstal first, but isn't help. than i did full sfp unistal with drivers and erase evrithing from system what have any conection with cw, then i instal sfp again.
but now i know. next time i will just replace file, it's much easyer.
thanks, devo :smile:
