Only recording on left channel?
Shampoo
Post by Shampoo »
Hi Guys,
I'm just finally getting my pulsar up and running, and i can now record, but for some reason i'm only get the left channel in SX. I'm guessing it's something to do with my routing and have taken a screen shot to see if any of you guys can tell me what i'm doing wrong.
Cheers.
<font size=-1>[ This Message was edited by: Shampoo on 2003-02-11 19:08 ]</font>
alfonso
Post by alfonso »
1)did you set your audio track as stereo in sx?
2)if you did, are you simply recording from the first channel(mono) of the adat source, that as you can see goes to the left channel of the first asio pair?
<font size=-1>[ This Message was edited by: alfonso on 2003-02-11 18:35 ]</font>
Shampoo
Post by Shampoo »
Hi Again,
Yep, I am recording in SX tracks in Stereo. Everything I do is only coming out on the left side. I just don't understand what i'm doing wrong in the routing.
"2)if you did, are you simply recording from the first channel(mono) of the adat source, that as you can see goes to the left channel of the first asio pair?"
In reply to this, yes i am, but what else can I do. The asio dest only works in pairs?
Should I put the first channel into the first asio pair left and right?
The the output from the desk is stereo, are the adat source tracks only mono?
Please excuse my naivety, i'm just still learning this all!
Cheers.
indeed, they are...
adat1 into left part of asio source, adat 2 into right :smile:
alfonso
Post by alfonso »
if you record a mono signal, make your sx track mono, and then the single asio channel will be ok.
