setting: 1 Pulsar2, 1 Pulsar2 SRB
When working in pulsar SW my mouse-pointer starts flickering. Pulsar hardware is unable to create stable samplerate in master mode. Even in slave it wouldn't connect to an external master sample-rate. The same thing occured some months ago. Switching pulsar cards helped. Did anyone encounter the same problems?
What can I do?
Sample Rate failure !!! Can´t work. Please help!!!
same problem!!
look here
http://www.planetz.com/forums/viewtopic ... forum=1&19
good-luck
if you work it out please let me know!
terranova-amsterdam
<font size=-1>[ This Message was edited by: virtualstudio on 2003-06-09 11:49 ]</font>
look here
good-luck
terranova-amsterdam
Hello!
I had experienced some weeks ago a similar situation. Clean with pure alcohol all the connections (especially the stdm) and make sure everything is well seated.
I wish you sort it out soon!
