I have put my pulsar in a small pc to use it as a router. This pc has no keyb, mouse or screen and is controlled over the network. It loads the default routing at startup as intended. So far so good...
The problem comes at shutdown. I can tell the pc to shutdown, but it then hangs as sfp asks to save an unchanged project while the network is down. I don't like to pull the plug each time and would like to disable this stupid question. There is nothing to save as there is nothing changed.
Anyone an idea?
						disable saving when shutting down
http://www.planetz.com/forums/viewtopic ... 8&forum=30
nothing much you can do about it at the moment i'm afraid
andy
the lunatics are in the hall
