Frequency Compositing?
I'm not sure if something like this exists already but Ive been thinking of this one for a while. Take for instance programs like After Effects, you can remove certain colors from video footage & replace them with another layer(ie blue screen effects). Since color is measured in frequecies I can see this being possible. I suppose you could look at it as a frequency dependent gate where instead of a sidechain input the gate is being triggered by a predetermined frequency  range in the primary signal & replacing it with the same frequency range from a secondary signal. Also have the amplitude of the predetermined freq range regulate that of the secondary signal. Maybe even have it set up to where you can select different frq ranges for both signal. Who knows, maybe this could provide some interesting results on anything from drum loops to synth pads.
