Big pb On Asusu P4C800 , HELP !!
Gaiza
Post by Gaiza »
Hi all,
first here is my conf:
P4 intel fsb 2.8
DDR400 ( 2 x 512)
Serial ATA (x2, 80 Gig)
Power Supply Enermax ATX-FMA
Windows XP Pro
Now my probleme :
windows (XP) randomly freeze ! first it start by the cursor (no change) and 3 seconds after os freeze.
My saler change my motherboard and my ram, but no change , it steel freeze.
i'v put the FSB mode to disable, no change
but if i unplug my pulsar2, everything is fine !
does somone have the same config ? please help !!!!
<font size=-1>[ This Message was edited by: Gaiza on 2003-07-26 16:29 ]</font>
petal
Post by petal »
Have you checked the PCI-bus speed?
The Pulsar is only capable of running at 33 MHz.
Well that was my first idea - it's propably not the problem though.....
Also, try to place the pulsar in different PCI-slots, it might make a difference.
Thomas
<font size=-1>[ This Message was edited by: Petal on 2003-07-26 16:50 ]</font>
Nestor
Post by Nestor »
Also, make sure you do not share Pulsar's IRQ with anything else, you must have one exclusively for using with Pulsar.
several here have the same setup with no problem.what order did you do the install in?the correct order(to a CLEAN harddrive that has been repartitioned and formatted)is:operating system,motherboard drivers,intel application accelerator,system drivers,creamware drivers,sequencer,sfp.go to the forum called tips and tricks andfollow the thread about optimizing xp.everything should work smoothly.
Gaiza
Post by Gaiza »
Thanks , i'll try it , hope this help....
cause i can't install drivers of my midi man biport too, it's a nightmare !
djdave66
Post by djdave66 »
try to disable the Intel Hyper-Threading Technology
mecanoiz
Post by mecanoiz »
What PCI slot is everyone using..? My scope card is bit too big for my case and all my periphals. So now its using pci 4 (5 is also possible) But it shares irq 23 with my raid controller (s-ata raid on deluxe version). Everything runs fine but i've got these nasty crackles when starting up and now and then some instrument hangs or freaks out (especially the newer creamware releases: minimax, vinco pro -one)
Satosh
Post by Satosh »
Have you seen this thread?
(in case you have something connected to midi-in on your Pulsar)
http://www.planetz.com/forums/viewtopic ... &forum=1&4
Also, if you don't use RAID, you can disable it in the BIOS.
Guest
Post by Guest »
things you need to do in the bios for this motherboard.
1. disable the onboard sound
2. disable the hyper threading
3. disable RAID
4. diable plug and play
5. don't hook up all the USB's a they take resources. this mainboard come with 8xUSB's and I don't think you need all of them.
make sure you got XP in standard mode
If you are going to use any Sony sonic foundry stuff you need to disable the onboard promise controller too.
cheers
Nestor
Post by Nestor »
If this gets too complicated, just go and kill your C drive with a kill application, like you can find in Seagate and Maxtor sites. Then do a complete reinstall of everything. If you can solve the problem otherwise, great, but sometimes solving a software problem is so complicated and it takes so much time, that it is much easyer, most of all if you have just started, starting from radical 0 again.
